Radius P1225 HT 2ch help
Skypilot007
Medford, NJ
I'm trying to get the VOX option to work feeding it with the line output from another radio. Will this work? I can get the audio to retransmit by manually pressing the TX button but its not triggering the VOX to transmit automatically. Is there something special I need? I have tried both mono and stero type plugs and cables.
Also if someone could explain the operation of the two buttons on the front. One has MON and the other has OPT. If anyone has an operators manual in pdf format or anything, that would be appreciated. Thanks.
Astro25
Chicagoland
It's been a while since I did programming on a P1225 fleet. Last I remember, the OPT button could be power save/high or low power/ and option board (if there was one installed on said radio).
MON just disables the current personalities channel opt. squelch code (PL/DPL) to CSQ mode on RX, and if you press and hold for 2 seconds you should get static.
Skypilot007
Medford, NJ
Thanks for the replies. I was thinking the VOX could be triggered by the line output of another radio for retransmisssion. Since the VOX from a headset is basically the same level of signal as a line output I figured this would work. Any other suggestions.....
