reddogracing
- Joined
- Jan 17, 2017
- Messages
- 6
Hello All !
New old guy here, about to raise a 70' (a little shorter) rohn 25 up against my house. House peak attachment point is 25'. Tower is 70' rohn 25 as mentioned and I ran green house framing 1 1/4-1/2 they entire length and extended 3' above the top. I used 21 clamps , 3 to each leg of the tower every 10' to tie the tower and tube together. The upper 20' has an additional 1" greenhouse frame inside of the bigger tube. Al this stiffens things up.
I put the tower up at 50' and am taking it down to add 2 more sections. I have a small tv antenna on top, and a 12" dish for internet as well. (interent is reason it has to go up higher.)
Real question is about raising the taller assembly. I have 2 pullys attached tot eh peak of house @ 25 foot. I have another pulley that can hook to tower to give me a luff tackle or jigger set up. What is the best places to attach for this lift??
I drew 2 options but there are more. I could attach everything at 25' like i did for the first tower, or everythign at 50'.
we will assist lift with tractor under the tower, as well as a line at 50' that will go over the house.
I am also debating on guys for this install. The tower is wind protected up to 45', attached to house at 25 ' adn i live in the country there is nothig for it to fall on but the house and even then gutters are only thing easily damaged, no porches etc and the house has a higher peak runing the opposite direction.
