Ramsey Co. Freqs.
1hdrdr
I am loading up my Uniden 996XT and I cant find the right control freqs for Ramsey county Mn./St. paul PD, /North St Paul PD./Maplewood ect. I Loaded all of the ones from Radio Ref. but I didnt get any hits with them. Im stumped
Raven95150
Nowthen, MN
The ones listed in the database for Ramsey Co. are correct. You just need to enter the red and blue ones, not ones in black. The red one is the main control channel and the blue ones are alternates.
Where are you listening from?
What are you using for an antenna?
Do you also have the talkgroups programmed?
Are you using ID Scan or ID Search mode?
