Larsen NMO-27 for CB use:
Chrome Whip -
https://www.theantennafarm.com/catalog/larsen-nmo27c-699
Black Whip -
https://www.theantennafarm.com/catalog/larsen-nmo27b-6439
Black Spring, Black Whip -
https://www.theantennafarm.com/catalog/larsen-nmo27bs-8342
Laird, chrome with spring:
https://www.theantennafarm.com/catalog/laird-technologies-c27s-691
Laird, black with spring:
https://www.theantennafarm.com/catalog/laird-technologies-cb27s-5585
Larsen Half Wave for VHF use, this is the complete antenna, NMO150HW coil and whip:
https://www.theantennafarm.com/catalog/larsen-nmowb150b-739
Laird Half Wave for VHF:
No spring -
https://www.theantennafarm.com/catalog/laird-technologies-b1442n-752
With spring -
https://www.theantennafarm.com/catalog/laird-technologies-b1442ns-7116
Larsen GPS antenna:
https://www.theantennafarm.com/catalog/larsen-gpsnmo02-3320
Laird GPS antenna:
https://www.theantennafarm.com/catalog/laird-technologies-gpsu15m-3321
Laird Cellular antenna:
https://www.theantennafarm.com/catalog/laird-technologies-tra6927m3nb-6167
All of these antennas will need an NMO mount base.
https://www.theantennafarm.com/catalog/larsen-nmotmb-1175
That includes the NMO mount, a bracket and you can have the connector of your choice installed.
You want to use the "HF" style mounts as the base is enclosed. The standard NMO mounts are designed for through-hole mounting on the vehicle roof and do not have any protection on the underside. That would be an issue on your proposed bracket mounts as it would expose the coax shield and center conductor to rain, snow, road salts, etc. which would result in it failing pretty quickly.
If you do not have the tools or experience for installing your own connectors, have them put them on for you. It can save a lot of headaches. Don't use adapters if you can avoid it, get the correct connector to fit the radio.
I'd still look at mounting the cellular and GPS antenna through the vehicle roof. That'll make it easier to get the cable inside. In fact, I'd also suggest taking a close look at mounting all the antennas that way. The bracket mounts will work, but getting the coaxial cable into the vehicle safely can be a challenge. You don't want coax getting pinched in doors or windows.
Done correctly this could be a pretty nice setup. Taking the time to do the antenna mounts right. Also, don't overlook power for all this stuff. Don't rely on cigarette lighter power. If you are going to be running a CB, VHF mobile, and a cellular BDA, run a dedicated power feed direct from the battery. Clean power, and lots of it, will be key. Tapping into existing electrical systems is a great way to get all kind of computer, ignition and other odd noises into your radios.
As for the SWR meter...
If you have no plans to run UHF, you could do one of these:
https://www.theantennafarm.com/catalog/diamond-sx20c-4833
Or, find someone local that has one, or a local radio shop, and have them do it for you. An SWR meter is handy to have, though.
As for exchange rates, maybe a visit south of the border would be a good plan, but not saying you should sneak it all back across….
