range of pro-94
gabyjan2291
tifton,ga
just got a pro-94 and someone told me that it would not pick up albany or valdosta ga. albany is 41.5 miles from me and valdosta is 48.7 would a different antenna help?
loumaag
Silent Key - Aug 2014
Katy, TX
It might, in the case of Valdosta an external antenna may work as it appears they are all conventional analog VHF. In the case of Albany you would need much more. 40+ miles trying to pick up an 800 MHz trunking system is problematic. A directional antenna may help but this would depend a bit on how strong the system is set and if it is directed in some way to preclude its signal for coming your way. The fact that you have a Pro-94 as opposed to some other scanner in no way affects this, you would experience the same difficulty no matter what scanner you had.
