Raspberry Pi + RSP2 + raspbian + Chromium
Olivehurst, California
#1
May be this has been discussed before, but here is my question.
I am trying to get my RPi3B+ and my SdrPlay RSp2 working ADSB.
I can get Dump 1090 to work on a terminal, but want to also get the plane plotter going.
All the examples I find use Windows as the internet interface.
Looking for a one computer (Raspberry Pi) solution.
Any help?
tnx for reading
jim vm
Cleveland, OH
#4
If you mean running everything on the Raspberry Pi - maybe. I run dump1090 on mine so that's definitely possible. SDRplay offers a Raspberry Pi image pre-loaded with drivers for the SDRplay and a few packages already installed, one of which is dump1090.
I don't use PlanePlotter, so I don't know if that's available for the Raspberry Pi.
You'd need to know how to image a Raspberry Pi and be proficient in linux to get everything working.
#6
ADSB + RPi
I have the image from Sdrplay running on my Pi. The ADSB works by displaying a BASH terminal, but
that is it. The documentation for dump1090 only shows how to make a windows computer work.
I have no interest in broadcasting my data, only wanted to experiment.
I have found Piaware and virtual radar server, might be the way to go.
The linux setup stuff is way over my head.
Thanks for the advice, will post if I get something working.
The Rsp2 rcvr works great with a discone. I can see all kinds of aircraft in my area.
jim vm
