RCI 2995DX
K4AOL
West Tennessee
What is a good amp to run with this radio? Before you try to explain to me linears are illegal, I know just don't care.
sloop
Lewisville, NC
RCI2995DX
1. Now that the power supply problem has been solved...that's a good radio. The specs are very good. Don't let anyone in it with a screwdriver if you are going to run an amp.! Any minor problem that they might create will be a major problem after its amplified.
2. With 50 watts and a good antenna, you don't need an amp. I talk about anywhere I want on 35 watts with a good antenna.
3. If you insist on an amp...then don't buy a cheap one. Get one made for hams, they will have a cleaner output.
4. Most of all be careful....make sure that your transmitter 50 watts won't over power the input (max. drive) of your amp. (that's why I suggest a ham amp.) and burn it out.
5. Ameritron, TenTec,Icom,and Yaesu all make good quality amps.
6. No, I don't approve...but if you must, keep it clean!
