RCS South site reband programming
K6CDO
Hanover Co. VA
Rescue_pooh, Give it a couple of days before you give up. We're chasing some gremlins in the system firmware (upgrading 25+year old computers is such a joy). I'll update the thread when the cell is completely retuned.
nhse
Solana Beach, ca
Let me update my own question. The new control channels are now posted on the radio reference frequency page in red and blue for the south zone. The east zone from the coast indicates they are on the old frequencies. Not sure when they will switch to the new rebanded frequencies as well as when they will switch the north zone. Does anyone have a firm date for the switches?
P71JEFF
Ramona,Ca
Well for some reason I can't get freescan to work on my BCD325P2 using windows 10, So I thought I would try programming as standard system by hand and it seems to be working ok, So here's the ? does it have to be programmed a custom system or not because as I said it's working as a standard 800/900 system on my BCD325P2.Thanks folks for the info
K6CDO
Hanover Co. VA
Scheduled for Tuesday 3/20 and Wednesday 3/21.
carlt
SD County, CA
I have reprogrammed all of my radios (325P2, 996P2, 996XT) using the information in the first post, and they ALL seem to be working fine.
nhse
Solana Beach, ca
North East RCS zone
I see there is a northeast zone with several frequencies, anyone know what this covers and if it’s active?
K6CDO
Hanover Co. VA
The NorthEast Simulcast cell covers the mountains & valleys along the 79 corridor north of Santa Ysabel to the County Line (Warner Springs, Los Coyotes, Chihuahua Valley) and the Palomar Mountain area. For discussion purposes, it is considered to be part of the "East" coverage area.
P71JEFF
Ramona,Ca
anybody have input on this. Thanks again folks and sorry to be a pest about this
Anderegg
Enter text in this field
San Diego
I changed my custom bandplan to standard 800 on my 996XT test scanner, both types seem to work without issue. I was assuming that the custom bandplan would allow the bandplan to operate on the prerebanded splinter plan as well as the full on rebanded system, which it did. Now that there is no longer splinter trunking going on, you should be fine just using standard bandplan. It may also be possible that the custom bandplan figures are actually what the standard bandplan contains.
Paul
celbaseman
Poway, CA
I was able to use Standard for the NE and S rebanded Simulcast systems, but when I configured for the East Simulcast I had to include the rebanding information provided by Anderegg.
scandiego619
San Diego, California
Uniden BCD436HP, RCS South
Hey everyone, I'm in a deep pickle. As I heard on this and other forums, RCS South is finished rebanding. I have a Uniden BCD436HP. I have updated the firmware and Sentinel with the latest versions but still do not pick up RCS South. (National City, Chula Vista, SD Sheriff (Lemon Grove/Spring Valley). It was to my understanding that all I needed was to update firmware and Sentinel. I'm not to tech savvy and any help getting me back up running would be appreciated.
boltman34
Hello all
I have a Uniden 396T with updated firmware and have tried the steps to reband the RCS South on my scanner so I can hear CVPD...sheriff etc. I have put in the info provided using freescan but still not working. When I scan I can see it saying finding control channel...what could I be doing wrong? I uploaded what I have inputed hopefully that helps. Thanks
Sent from my SM-G960U using Tapatalk
Anderegg
San Diego
Looks correct to me, our 996T's accepted and work with that programming. You can delete the 866-868 control channels, the current working control channel is 853.4125...maybe set it to Motorola 800 Standard Type II with only 853.4125 as control channel, that seems to work now that rebanding has completed.
Paul
boltman34
I switched to the standard 800 II and its working now. Thanks for responding. Glad to have my channels back. :)
Anderegg
San Diego
If the SOUTH RCS system is in a favorites, access that in the menu, and change the bandplan from 800 splinter to standard 800 Type II. Change the control channels from the 866-868 ones, to the new 853ish ones in the first post. That should do the trick.
Paul
