RDV2020 question
Yukon, OK
#1
I would like to set the frequency on my RDV2020 to 154.57 frequency, which is a MURS channel. I have the CPS but doesn't give me the option (because it isn't a MURS radio), but the frequency is in the range for the radio.
Is it possible to get my radio to operate on that frequency? What would I have to do (can it be done by me or do I have to take it to a dealer?)
Sonoma, CA
#2
You might have tried the commercial Motorola forum for this.
The RDX series is a low tier model and has limitations. Your RDV2020 can only programmed with a certain frequency list, i.e the "dot" business band frequencies. If it's not in the CPS list, you cannot put it into your radio.
Now all you need is someone willing to hack the codeplug and you're all set.
