OK, I'm gonna ask a stupid question: doesn't the scanner (Uniden 396 original version) just use the info in the control channel to tune? So I shouldn't have to add/change a bunch of freqs when they re-band as long as the control channel(s) stays the same. Right? or am I missing something...
As one of the past presidents said, "Read my lips", all channels moved down 15 MHz when rebanding takes place. This means not only do the voice channels move, the control channels do also.
Think you can figure it out from there?
What's with the need for sarcasm?
Did below comment answer the question asked above regarding the 396 scanner? If so, I can't find it.OK, I'm gonna ask a stupid question: doesn't the scanner (Uniden 396 original version) just use the info in the control channel to tune? So I shouldn't have to add/change a bunch of freqs when they re-band as long as the control channel(s) stays the same. Right? or am I missing something...
You've only been Blunt thus far in this thread which is sarcasm IMHO.Call it what you want, but the way I see it, rebanding has been going on for some 3 years now. It has been discussed for at least that long all over the web including on here many times. Yet there are still those out there in the never never land that haven't got a clue why their scanners suddenly went silent. Then they post a message asking what happened. Been in this radio field way too long to have to put up with such slow readers.
It would seem that no matter how polite or blunt you are, someone will always complain.
Ok today I changed the frequencies in both my 396XT and PSR500. Both are receiving the control channel, and showing me the system ID, neither radio is picking up any traffic, even when it stops on a talkgroup, no audio. Anyone else having this problem or is it just me?
Using Scanner menu set Wayne's table. http://forums.radioreference.com/ra...6-2096-rebanded-motorola-trunked-systems.htmlOk the 396XT is working great. So what's the "fix" for the PSR500 to receive it? How do I translate the custom band plan to that scanner?
