I have a scanner that scanned on a 800mhz analog channel, now the ES have changed to 800mhz digital, how would I reprogram to be able to scan these channels? I have a Uniden BCD996XT. Thanks for the help.
if you are doing it by hand you goto menu then program system then new system then P25 then standard trunk then confirim then scroll to edit site then click then click new site then goto set frequencies then new frequency if you do it by computer its alot easire cause the all you have to do is tell the program to change to P25 at least on freescan in stead of creating a whole new system manually
