Baofeng re: programming a UV-5RA
steve-kc7byp
West Richland, WA
I have a Baofeng UV-5RA, VHF/UHF HT. The OS in my laptop is Win 10 Home 32bit The interface cable is working, Device manager is showing the interface cable on com 5. I can upload the radio's memory ch's Into Chirp. But I can't upload or see what is in the 2 VFO ch's. I can only see on Chirp what is in the radio memory ch's 0 to 128.
How do I make the radio upload what is programmed into VFO's to Chirp. Also this ht has 2 progable memory banks ch's 0 to 128 in each bank.. Chirp is only seeing memory bank 0. When I prog ether memory bank by hand the radio works fine
Josh380
Orange County, CA
If its anything like the uv-5r, it won't upload vfo programming..I don't believe vfo programming is stored quite like your channel memory is.
steve-kc7byp
West Richland, WA
That is possible about the VFO programming. But I do know that the UV-5RA has 2 sets of channel memory banks. On the ht there is a button to select memory bank (A) or (B) and I know this because when I got this ht (used, in good conduction) a few years back. Ch (A) memory bank was about half full of repeater and simplex frequencies. Bank (B) was filled with FRS frequencies ch's 1 to 22. I messed with the FRS frequencies a bit at home. I have a set of FRS ht's. I was in the hospital for a while and my nephew was playing with the ht without me knowing about it, or my ok. Some how he found setup menu #40 reset (restore everything to factory default settings). He put the ht back the the factory default settings, wiping out the memory. Now I have to reprogram the ht and Chrip only sees memory bank (A). I don't know how to reset Chrip to see memory bank (B).
