Reading 800mHz freqs
tjpuclik2
MWC, OK
How do I read these freqs in the database? I'm not understanting how to match up or pair off each channel for an area.
I'm looking at El Paso Tx Polce Dept.
Thanks for the help
tjpuclik2
MWC, OK
So people can read my post but not respond. Great what help this was, I'll just try to figure this **** out my self.
GemmaKnight
Massachusetts
Dude or Duddette, this is just a suggestion but be a little patient. It usually takes a day or two for someone to answer a question here. :)
rdale
Lansing, MI
Go to the Wiki above and read the introduction to trunking.
loumaag
Silent Key - Aug 2014
Katy, TX
Let's see, you have been a user on this site for better than a year and half; your very first post was a question which took almost an hour to answer and you didn't even acknowledge the help provided. In this instance after an hour and half at the wee hours of the morning you are upset because someone didn't answer your question; a question that needs no answer BTW. And then you answer with foul language, I suggest that you take a step back and consider that you have unrealistic expectations, that is if you even bother to read this reply. :mad:
