Realistic model 21-1642A manual
KF0AWL
Hobo
Iowa
Anyone have a manual for a realistic TRC-224 3 CH handheld cb?
I have 2 of the handheld but no owners manual to see if the work 🤷🏽‍♂️
WSAC829
Jack of all trades. Master of none.
EN64ak
I hear ya. At least it’s only $8. Some other vintage manuals are $20-ish or more.
kc2asb
NYC Area
I'm guessing this is probably an 80's era model. There is nothing spectacular about this model handheld, but it's not junk either, unless the two you have are in particularly bad condition. The majority of Radio Shack's radios from this era were manufactured by General Research Electronics of Japan (GRE). Build quality was generally good and they worked as advertised.
Have you tried loading fresh batteries in one of them to see if it powers up? Usually, they take AA cells.
KF0AWL
Hobo
Iowa
I didn't do batteries but I did make a 12v input wire from my power supply, one made noise the other didn't do anything. Mainly I'm trying to figure out what freq A B C are so I know what to listen for 🤔
kc2asb
NYC Area
These handhelds required crystals and could operate on any three (3) of the 40 CB channels. The frequency and/or channel number would be marked on the crystals, which are installed in sockets inside the radio. I'm not sure if the crystals are accessible by removing the battery compartment door or if it requires opening the radio. Making noise is a good sign. Perhaps the one that didn't had the squelch control turned up. The squelch silences the speaker when no signal is being received.
KF0AWL
Hobo
Iowa
I tried turning squelch full both was and got nothing. The battery compartment is just battery so I'll carefully pop the back off and look at the crystals..
Do the crystals just pop out?
I'm a HAM and buy the SILENT KEY little drawer cabinets of stuff nobody else wants for parts and know i have some crystals in there 🤔
kc2asb
NYC Area
The crystals have two pins that insert into sockets on the PC board. Pull up gently to remove them. The frequency is often stamped into the top of the crystal.
wtp
Port Charlotte FL
wtp
Port Charlotte FL
page 24
comes with ch.14 crystals.
remember, one for RX, one for TX.
at least you have to catalog numbers for some of the crystals.
kc2asb
NYC Area
page 24
I had that catalog....might still have it some where. Getting the new Radio Shack catalog used to be a big deal. Lost a decent amount of time on that website, too.
  • Like
Reactions: wtp
KF0AWL
Hobo
Iowa
page 24
So I'm not long on cb no how lol
It works on channel 14 only? Or what's with the ABC?
Tried to open it but it wasn't happy to come apart so I didn't want to force it. Any advice on how to get it to cooperate?
One scre top right corner on back and 2 in battery compartment was all I saw.
kc2asb
NYC Area
No,WTP meant that it came standard with crystals for Channel 14 installed. The purchaser could add crystals for the other two channels. ABC = 3 channels.
Not sure about how to open it.
KF0AWL
Hobo
Iowa
Well that's the end of that. Batteries must have exploded inside, if im hooked into 12v the one works but Batteries I get nothing. But I push the red battery test button on the front its bright as can be!? 🤷🏽
