Realistic TRC 48 CB Radio
castking
Maple Ridge, British Columbia. Canada
I was given a trc 48 CB but the power cord wasn't with the radio. I called Radio Shack, they no longer carry the product. We are in the Bellingham area often, if you have any ideas where I might be able to get a power cord I would appreciate the help.
Arkmood
Taney County MO
That's a 23 ch.SSB CB, one of RS's best back in the 70's - it may not power up even with the power cord, but you can get one here:
Ken's Electronics
DC-TRC48 Realistic CB radio DC powercord 6ft 16ga 5A fuse 4-Flat-Blade-Pin Cinch-Jones
You can order online and they ship to Canada
CONTACT information and FREQUENTLY ASKED QUESTIONS at Ken's Electronics, (Wholesale & Retail Electronic Parts) Kalamazoo, Michigan
1OFGODSOWN
TRC-48 POWER CORD
I have TWO of these rigs.One has the wall plug & the other does not.I use the one without the wall power cord with a 12 volt power supply.The wall power cord does NOT power the other radio up for some reason so I'm guessing the internal power supply is bad.The top 2 pins are positive & the 2 bottom pins are negative in case you have not looked inside the case & it's easy to make a 12 volt set of wires for it.The wall plug is NOT worth the price they want for them when they operate just as well on 12 volts.Good luck! {:>)
SIX-SHOOTER.
