nevesjerry
Hello to all Members
I have a question regarding constructing a Vertical antenna that would cover from 500 kHz to 30 MHz.
I do have an RF Systems passive antenna which is about 6 feet tall fed with coax cable and it gets fantastic
reception on AM band as well has SW. Obviously this antenna is fed with a coaxial cable with a PL259.
I always wonder what’s inside this unit, and I know for sure it has a wire elliptically wond inside. Other than that I have no idea. My question is when you feed a vertical antenna with coax cable would the wire inside the antenna connect to center of coax feed line, where does the braid of feed line attach to inside the vertical?
Is there a magic transformer inside the antenna? Perhaps a balun?? The commercial RF Systems vertical has no radials or a ground connection!
I am puzzled. Any help appreciated.
Best regards to all, Jerry
