razorhead89
- Joined
- Mar 18, 2007
- Messages
- 14
is buying the batteris and charger worth it...or should i stick with just one time us batteries?
I bought an 8 pack of the 2650s and ran them in two scanners (one a PRO-97). All of a sudden the PRO-97 whouls show low battery as soon as I disconnected external power. Upon further investigation I found one of the 4 batteries to be absolutely dead.Russell said:Wow, I've had excellent success with the Duracell 2650s. I have like 16 of them. I'll keep them in the 96 and 97 and charge them in place. The other two sets I will charge in the big charger and rotate them out occasionally. I love them, they last forever.
Russell
icom1020 said:I'm not a big fan of quick chargers, I think heat means wear. I use an Emerging Power smart charger that has the microprocessor. I used the 2650 Duracells but the charger seems to flash the eval code for a long time. I havent tried them one at a time yet, I did with a Rayovac quick charger and that seemed to work but time consuming, plus it has always heated up regardless. I believe from reading up on this that the Emerging Power EP-4. charger is rated for up to 2100ma so that is the type I have to use, as I want the batteries to be evaluated before a charge. I have used the Rat Shack ac power adapter to charge the Duracells in the 97, but I think it would better to charge outside the radio. Anyone recommend a smart charger for the high capacity batteries?
Ok, so how long does it take for the Duracell Smart Charger to charge a set of 2650'? and are they warm, not hot?trunker0205 said:I never charge them in the radio, I have a Duracell smart charger when the flashing light goes out they are done and it will not overcharge them that is what kills rechargables.
Yes, it sounds like they were not fully charged the first time.KrazyKevin said:I just bought a pack of Duracell 2650 for my new Pro -97. I only have the Energizer 15min quick charger though. On the first charge on the Duracells using my Energizer charger, I'd say the batteries lasted 8-10hrs. I had the volume turned down and the backlight on. Could this be because of the first time use and they haven't broke in yet, or using the energizer charger to charge them. The only thing that I could see a issue with is the energizer batteries are 2500mah and the Duracells are 2650mah. What do yall think?
Ps. What do yall think about letting the Pro-97 doing the charging? Would it be better or worse than my energizer 15min charger at charging the higheer mah duracells?
