SDS100/SDS200: "Recharge While On" resets to Disabled
NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
Hammond, IN
So I've had my latest SDS100 for a little over a week now, and as with my previous two 100's, I'm loving it. This one, however, has a small issue.....
Until I have the $$$ to get an extra battery with the external charger, I obviously have to charge the battery while it's in the radio, which I don't mind doing for the time being. What I'm running into is when I have the radio charging the battery while on. It works as it should....however, when I turn the radio off and then turn it on again after a little while, I find that the 'charge while on' option has reset to "disabled," and I have to go into the menu settings to enable it once again.
This isn't a "big" enough issue to warrant its return to the seller or a trip to Uniden for repair (if that would even be a repairable problem). It's just a mild inconvenience that I'm wondering if anyone one else has encountered, or it's just a gremlin in my radio.
licpl8man
Southbury, CT
What is it plugged into? I run into this with mine if the USB source doesn’t have enough horsepower to keep up with the power demands of running the radio and charging at the same time. Even more so if I have multiple things plugged into the same power block
NWI_Scanner_Guy
Hammond, IN
When charging, it's usually plugged into a standard wall outlet with two USB outlets built into it. Only my laptop is plugged into the standard outlet and the scanner is the only USB powered device plugged in. I haven't gotten the 'low voltage' (or however it's worded) alert, so I'm pretty sure it's getting all the juice it needs.
werinshades
Chicago , IL
I would ask to have it exchanged if you're within the allotted time. Since you have other SDS100's, you know this isn't normal behavior.
fxdscon
¯\_(ツ)_/¯
It's a common issue (feature?) that when the SDS100 is connected to an adapter that doesn't have enough power to adequately charge the battery while the scanner is running, the "charge while on" menu setting will normally reset to disabled. A USB charger of at least 2 amps will allow the charge setting to remain on. There have been a number of posts on that.
RandyKuff
Lorain, Ohio
I'll almost bet the usb ports built in to the outlet can't deliver the power needed to run and charge the scanner...
So it might be kicking out the charge function on the scanner...
NWI_Scanner_Guy
Hammond, IN
Hmmmm, the USB outlets are rated at 2.1 amps, so it should be getting the power it needs.
NWI_Scanner_Guy
Hammond, IN
I’d try using the Uniden supplied usb wall adapter and cable and see what happens. My experience with the USB ports built into a outlet are they don’t provide a lot of current.
I've done that while having the scanner with me at work, and I have the issue with the Uniden items as well.
fxdscon
¯\_(ツ)_/¯
Do you still have one of your other SDS100s? Maybe try swapping batteries to see if the battery is drawing more than it should to charge?.
RandyKuff
Lorain, Ohio
Open the battery cover and press down and wiggle the battery around to wipe the contacts and see what it does...
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
Usually this happens with my SDS100 while I'm connected to a laptop's USB port, screen will read USB LOW BUS VOLTAGE or something to that effect, after which the "charge while on" setting will become disabled. I've charged it on various USB wall outlets, never noticed the issue there. Definitely something unusual going on with yours if the supplied OEM charger causes the issue
RandyKuff
Lorain, Ohio
I've seen the OP's problem on my 100 and the external charger...
Both the 100 and the external charger have very small pin surface areas for contact compared to the batterys terminals...
By pressing and wiggling the battery around to wipe the cantacts corrected the problem for me... I do it when putting a battery in the external charger and also when swapping the battery on the 100... Have not seen that problem show up since doing that for me anyway...
It's more than likely the charge sense contacts that have the issue with dirt, oxidation or whatever... Not the power contacts...
EricRF
Arlington, MA
OK, this is creepy... I've had my SDS100 for a couple of months. I've always charged/used it while plugged into my laptop, and it's always been fine. That is, until I opened this thread, discovered the red charging light was off and the "Charge while on" menu item had reset to "Disabled".
I've noted all the suggestions above, and when I re-enabled "Charge while on", it seems to be charging quite happily. It's just so weird I only noticed the problem when this thread came up. It's close to Halloween, so I guess that has some thing to do with it. 😜🧙
JethrowJohnson
I love P25
Marietta OH
Someone's watching you 😶
RandyKuff
Lorain, Ohio
Each...?
Or, total?
Somewhere, you don't have enough voltage - triggering the disabling of charging while on.
This is a 'feature' - not a bug.
Normal behavior if voltage drops below X VDC
Acording to him it does it with the Uniden adapter too... Post #10
nessnet
Eastside of Lake WA
He didn't specify if the stock USB cable.
OP:
Is this with the STOCK USB cable?
Or, one you pulled out of the parts drawer?
Note:
The cable has to have 24AWG power wires in it.
The stock one does and any other cable needs to...
