Recommendation for antenna cable to handheld
trauts14
#1
Can anyone suggest a good place to buy 75' of cable (LMR-400?) to go from my handheld scanner to my antenna? It would be best if I could have the cable made with a PL-259 on one end (the antenna), and a SMA male for my Yaesu and BCD436HP. I am not sure what companies offer custom adapters for this. Thank you for any assistance.
questnz
Somwhere in South Pacific
#2
Ive got similar arrangement with my scanners with 5D-FB cable, you just buy short 2-3m (or shorter if you need eg 6") RG174 or RG316 pigtail cable with SMA connector on end to feed your canner. The loss is minimal for short run and work vell with receive only requirement.
trauts14
#4
