Good Evening All!
I need a little input on a small issue with desense occuring in a VHF repeater system at a site with no other equipment other than a 900mhz SS link radio for telemetry control at a tank site on a 1600'ft hill. Here are the spec's:
-Vertex VXR-7000 running at 50-watts out
-Telewave TPRD-1554 4-can/5" BpBr duplexer with ~77dB isolation (per the spec's) at 1.5dB loss
-RG-214 double braided coax between repeater/duplexer
-38'ft of 1/2" LDF4 Heliax
-15'ft of 1/2" Superflex (between duplexer-lightening arrestor and jumper to LDF4)
-Lightening Arrestor mounted to cabinet (don't remember brand)
-Telewave 2.5dB VHF (First Antenna)
-Commscope DB-222a 2-element 3dB/6dB exposed array dipole (2nd antenna)
My issue is that with the original Telewave antenna, no desense was occurring that I could perceive enabling/disabling the tx on the repeater with a weak station, but the antenna was not receiving very well and kinda deaf. I installed the dipole in an omni configuration and I started getting desense on the input. I then switch it to a directional antenna with the null of the antenna to the repeater, and almost all of the desense went away. In this configuration the repeater is working quite well and I am now a believer in dipoles. I would prefer it in a true omni configuration as HT's in the null are weaker then they used to be, but it's doable in this configuration.
I have a Wacom notch/bandpass filter cavity (can be configured either way), and was wondering what might be best; install it on the rx of the repeater, notching out the tx frequency. Or set it up more as a single pre-selecter in a bandpass configuration on the rx side of the repeater to only allow the rx frequency through. It appears that at 2mhz away, I am getting ~18dB of isolation in a bandpass configuration with a 1/2dB of insertion loss (per my VNA).
So what do you experts think or feel? I may go to the site and test both configurations, but leaning towards the bandpass configuration with the cavity located between the existing duplexer and repeater rx port. Do the cables need to be a specific length like the duplexer's need? Any help would be great!
