recommendations
ffjsh
Dartmouth MA
i hooked up the scanner to the computer with a 3.5mm cable one end in the Line In on the computer and the other end is on the headphone jack on the scanner. Ive been at work all day im gonna try to tweek it in the morning
ffjsh
Dartmouth MA
I fixed my issues, i pluged the cable into the ext speaker jack on the scanner instead of the headphone jack, then adjusted audio in the settings
