Recording Uniden Audio To iPhone
Boston, MA
#1
Anybody know if one can record audio from a Uniden to an iPhone using a TRRS adapter. It's my understanding the iPhone requires a different type of TRRS adapter for a powered mic vs. non-powered. If it is possible to use the headset output on the Uniden as a mic going into the iPhone, then any ideas as to whether it would emulate a powered mic or not?
AnikF1R
Minnesota
#2
I've gone from a cable box (RCA connectors) to a TRRS adapter to my iPhone. It worked just fine and should be similar to what you're trying to accomplish. The only thing is that I used a Line Level TRRS adapter, not a Mic Level one. That may be what you're referring to.
