Recording using computer
ayaresr
I am looking to record from my scanner to the computer. Anyone know of a good program (prefer shareware)?
flex
Yea scanrec works well.I use a program I bought a few years back called replay radio.It never even occurred to me to use it to record my scanner till about a month ago.Works better then scanrec but not free.
R
rescue31210
Guest
I'm also trying to record audio, but I need to record all audio on my repeater system. I tried downloading Scanner Recorder, but I can't get it to start recording. Does anyone know how to activate the recorder on it?
Thanks.
smason
Alberta Canada, Eh!
Thanks.
Click file, open, give it a file name, select a quality, click ok, then click record.
R
rescue31210
Guest
Ok, I got that. But now how can I select a destination for the file, and how can I find the file after I'm done recording?
Thanks.
k9rzz
Milwaukee, WI
Scanrec: The file has to exist before you can begin. With most software, you record and then name the file. Scanrec is backwards in that regard. It's been a while since I've used it, so if that's off ... sorry! Good FREE program though. Keep playing with it, you should be able to figure it out.
John K9RZZ
dirtfinder
Still in the middle of no where
John K9RZZ
Yeah you have to set up that folder in My Music not that hard just click new folder and name it(name what ever you want), it is just the way I did it, makes it easier to find, that way you are not searching where you sent your recordings
