N0BDW
Hi all,
I have a Yaesu FT-8800 as my primary rig in my car. It is hooked up to a Comet CSB-790A antenna that is mag mounted to the trunk. I also have a Byonics Micro-Trak RTG that uses a Micro-Trak VHF Antenna V3 antenna. The problem I'm having is that I'm hearing the APRS beacon come through the speaker for the main rig. I'm fairly new to the hobby, but I'm thinking this is either a problem with the antennas being less than 1 full wavelength apart or the speaker is picking up the RF from the APRS transmitter.
So, what can I do to reduce the likely-hood of this problem? I thought about getting a duplexer (not a diplexer - any recommendations?) so I could run both transmitters off the one antenna... and/or installing a ferrite core on the speaker wire...
You can see my setup in this thread:
http://forums.radioreference.com/pi.../197055-mobile-install-2006-chevy-malibu.html
Thanks for any suggestions.
Ben N0BDW
Ben N0BDW
