I have a M400 which uses the same case style, the AC adapter says 12 volts AC output. If your MX3000 is like my M400, there should also be a separate red colored jack that takes 12-14 volts DC since these radios were designed for mobile or home use. It will take the positive side and the negative side of the DC is attached to the chassis ground screw. The small black plug is for the 12VAC. Either way, a 0.8 amp minimum is required.
You would need to be more specific about which model, some were made by Bearcat/Uniden, and also depends on whether you're talking about base or handheld.
On AC, there is no positive/negative pin. As long as the wal-wart that you are using is 12VAC, then it won't matter which wire is what. As far as DC is concerned, typesix took care of that. The red connector is 12VDC positve and the chassis is ground.
