Regency R806
Marty28472
Does anyone know if you can put all (8) low-band vhf crystals in this scanner or do you have to go by the way it is programmed (combination of vhf and uhf low and high bands)? Thanks
52to12
south eastern NC/Dutchess Co.NY
You can install all low band,all high band ,all uhf or any combination.
Just remember that the connector at the end of each program wire must be connected to the correct pin for that band.If there is no crystal installed in a socket,the program wire can be connected to any pin.All wires MUST be connected to a pin.
