Regular TV antenna has my SDR software, It works?
joeuser
North Central Kansas
#2
This is a TV antenna and the elements on this antenna are horizontal. If you could configure the elements vertically it would perform much better. As it is configured right now, horizontal I'm not sure how good it would do. You may also have to consider an adapter to go from the antenna line & into your dongle. HTH!
popnokick
Northeast PA
#3
TV antennas make good broadbanded scanner antennas. But you should rotate the axis of the elements ninety degrees so they are vertical.
New Zealand
#4
...and I doubt that it's frequency response gets down to 47MHz. There is no such thing as a digital antenna, only an antenna that suits the UHF band that your digital TV is broadcast on in the US. Here it's around 400 to 700MHz.
UK
#6
You could just turn in 90 degrees.
That antenna will be directional at its resonant frequencies and will be relatively deaf behind. The quoted frequency response is nonsense, unless they consider 8:1 SWR as "resonant", with IS nonsense.
