Relm 599A problems.....
cdknapp
Rochester, NY
I have both a Relm UHF and VHF portable that I use as extra/reserve radios for work. I haven't used them in quite some time. After recharging them, I found that the UHF had actually lost it's progrmming, and the VHF retained it's programming, but is now asking for a password to access it with the software. There is one small problem: I NEVER programmed a password into it! This just appeared out of thin air. Does anyone know of any work-around for this? I don't feel like trying 100,000 passwords to truy to figure it out!
Thanks for any help!!!!
fineshot1
NJ USA (Republic of NJ)
I don't know much about the relm series of radios but i have seen
some others ask for a password when attempting to access the
tuning or adjustment menu's. Is it possible that is what the radio
is in - a menu for adjustment. If there is anyway for you to try
backing out of that menu?
cdknapp
Rochester, NY
No, it isn't possible. When I plug the radio in and boot up the software, it instantly asks for the password before I can do anything.
cdknapp
Rochester, NY
Okay, with help from Relm, I have my answer, which I'd like to share with everyone. Apreantly, when these radios haven't been use for a while (dead battery), the memory dumps. Open up the software, and you will find some 'stock' fx's in the software. Do NOT attempt to read the radio, but just upload the stock fx's to the radio. That clears the memory, including the asking of a password. After you load these stock fx's, then you can load anything onto the radios (like the saved file that I had for it), and it goes wothout a problem, and clears the need for the password.
cwilliam
Inwood, WV
I hope this is the right place for my question.
I have a Relm RPV599A that I somehow erased all frequencies from the keypad. I am able to program it form the keypad, however, it now beeps constantly and I can not recieve or transmit on it. Any suggestions on this. Would I need to get someone with the software to reprogram it?
1268
I have undone that issue on a Relm but without having it in hand tough to say what's wrong. Short answer yes you need to get the windows programming kit and reload it. usascan sells the software and cable among others.
cwilliam
Inwood, WV
Thanks, I'll try that then.
