Remote Reboot Device
brandon
SoCal
I am in the market to purchase a remote reboot device. I have a scanner and computer at a remote location and sometimes the PC tanks and I need to reboot it.
What product do you all recommend to remotely reboot a device? I found something called iBoot however the price is holding me back. Is there anything cheaper than 200 dollars out there? If not, I guess it's time to save some $$$
Thanks for any help.
Colorado
You can do a re-boot with a remote service such as www.logmein.com . You can access the remote computer from anywhere, and if need be, you can re-boot it. I have the service and use it to check on my scanner-feed computer (which doubles as my weather station). Best of all, the basic service is free.
pfish
That wouldn't help if the machine wasn't accessible (crashed). Also, instead of using a web-based program such as LogMeIn, I'd recommend using a VNC-style method such as TightVNC (www.tightvnc.com). There's no 3rd party there, its direct between IP<->IP.
poltergeisty
Deep Thinker
RLG, Fly heading 053, intercept 315 DVV
Would it be cheaper to fix the PC? Or is this just a slow old tank? What kind of PC do you have? It could be loaded with all kinds of spyware and crap. Do you use a firewall? PSU in good shape? Hows the RAM looking? Defrag lately? Scan disk could help. I reformat my hard drives often and reinstall the OSs. Perhaps you could benefit from a separate partition for the scanner connection.
kd7rto
Bountiful, Ut
Linux would be much more reliable than Windows for long term, unattended operation. First thing, though, you should investigate whether the lockup problem might be hardware related.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
n6orz said:
The best fix would be to dump Windows, and get Linux.
OK, I think Linux has it's place, just as a Mac does, but it's not for everyone. if the OP has Windows and is able to use it, then maybe he should use it. the learning curve for Linux is a little bit more than Windows.
Yes, I would agree with fixing the PC first.
kd7rto
Bountiful, Ut
I'm in the process of setting up a remote receiver to be placed 750 miles away, and I consider Windows too unreliable to use in such an application.
rayveedub
wow awesome question. i never though of this before myself. my prob is very similiar but i need to be able to log into the remote computer using the control alt delete. are any of these programs able to log you in as well as reboot?
newbie
St Clair, Michigan
If you are running windows Remote Desktop comes on xp and allows that. I wrote a very small executable to reboot my machine. I have found the need to reboot mine remotely as well. But you need to be able to login to do that.
