Removing "Caller ID" from Scanned Frequencies
jwboudreau
I am trying to find a way to remove the caller ID from scanned frequencies but have it still recognize the ID from radios in my fleet. The Caller ID's on the scanned frequencies do not allow the radios in the fleet to see the name of the Department broadcasting on scan (at all times). I have found the Caller ID check box but as I said above, I want to continue to receive the Caller ID for those radios in our fleet, just don't need them for other Departments in our area. Any thoughts?
kd4efm
Florida
No real way, on or off. No in between.
kd4efm Evans, sent using TapTALK on my HTC M9
jrw14493
FW mod for 5000 series? Hint hint :)
I've run into this problem before too EFM.
kd4efm
Florida
Wishful thought. Don't see it being that way. I'm sure there may be a way, but not right now. It's either on or it's off. Even with audio option, my radio decodes mdc or fleetsync even on a pl/dpl channel, even when the code is not correct. I have that issue with a Co channel in Tampa.
