My feeds record everything in the usual half hour segments. I've noticed that a couple of other feed archives remove the dead air time. How is this done? I can't seem to find the place to turn on this option.
Joe
Joe
Joe
I use a programme called "ScanRec" - you can set an audio squelch which stops recording when there's no input. Stereo too, so I record the output from two scanners. You can choose to keep all the audio as one, or split it up into separate sections.
Scanrec Scanner Recorder
I guess it's not a user option for Broadcasity to truncate silent times.
Thanks for the tip on Audacity. I'll try it out.
