repair and rebanding
warren michigan
#1
i have a rs pro 96 and soon will need to sent out for rebanding and some repairs it may need . the question is do they have to be sent out to rs or is there repair shops that can do this.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
#2
The 96 cannot be "fixed" for rebanding by any repair shop. Instead, using Win96, one can set Custom Trunking tables for rebanded Motorola 800 systems.
Depending on required repairs. RS will cost you 49 bucks plus shipping and cost of parts.
warren michigan
#3
fmon said:
The 96 cannot be "fixed" for rebanding by any repair shop. Instead, using Win96, one can set Custom Trunking tables for rebanded Motorola 800 systems. Depending on required repairs. RS will cost you 49 bucks plus shipping and cost of parts.
ok sounds good i think the antenna connection needs repair gettin a little scratchy on 800 mg but not sure
