D
Drake1731
Guest
Hello. So I have a duplex repeater setup, and I have an issue. So I have 2 Wouxun KG-UV920Ps with the repeater cable. I have them both connected correctly, everything it setup, etc. Then I have 2 Baofeng 888's acting as a small duplex system as well. The Baofengs have a small repeater controller connect to each of the accessory ports. I try out the repeater, on UHF 400-470. And not a lot of luck. For both. I can go further with no repeater than with one. The KG-UV920Ps were set to 10 watts for testing purposes, and the baofengs, to my knowledge at 5 watts. The KG-UV920Ps have the same antenna, and are setup correctly, but it doesnt make since to me that talk around goes further than a repeater.. Any help? If you need anymore information, I'd be glad to provide it.
