Repeaters
#1
Can someone direct me in how to use repeater to extend the range of my baofeng uv-82 i can use chirp to program just don’t know how to setup using local repeaters
Fortunately, GA
#2
Provided you are a licensed amateur radio operator, knowing the frequencies and CTCSS/DCS tones are the most important to getting the radio to access the repeaters. Also, you need to know if the repeaters are +/- on the input.
If there is a ham radio group near you, you should ask them for help.
HTH,
Larry
jwt873
Woodlands, MB
#3
There are GMRS repeaters in some places as well..
A bit more information would help.. (Where you are, what repeaters you want to access, etc)..
#4
I’m in Manhattan KS. I was looking up repeaters in my area and seen one that covers a recent range, I believe the repeater was W0QQQ. Im in Manhattan Kansas if that helps. Riley county
North Texas
#7
Hi that is a club station that have a 2 meter and 440 mhz
Repeater .I would look up the Univ and talk to the club .
For info . You will need a license to use the machine
If you have your ham lic you are good to go one of the repeaters needs a tone to access it.
Welcome to the form.
