Mr. Moderator - please relocate this if you think it's in the wrong place.
maybe install a discriminator tap by an experienced solder man with rock steady hands & a hard eye,
I've just done that with a BCT8. It's probably not quite a discriminator tap but it sure makes the audio sound a lot better and it works for pocsag, satellite pix and other digital stuff.
You'll need an RCA phono socket chassis mount with a nut and two washers, about 6" of fine insulated wire and an electrolytic capacitor 10uF 16volts.
Take the bottom cover off and disconnect the speaker by pulling on the white plastic connector and release the wire from the loop of black plastic coated metal..
On the bottom right hand side below the D connector there is just space to drill a 1/4" hole to take the socket, the two washers and the nut. If you are really lucky, the bracket underneath will jam against one the flats on the nut and you can tighten it very well with a pair of multi-grips. There is no need for the grounding solder tag. Cover the PC board with a paper towel and put grease on the drill bit to catch the swarf. I prefer to drill a small pilot hole then open it up with a tapered reamer.
Shorten the positive lead of the capacitor and make a loop in that lead. Shorten the negative lead and make a hook in it.Hook the negative lead to the centre tag of the nut and solder. If you want to be really professional, secure the capacitor to the side panel with non-acid cure silicon sealant.
Get a look at the square green printed circuit board attached to the back of the volume control. You'll see four solder blobs in a square, three blobs in a line and eight in a line along the edge. You're going to attach one end of your wire to the bottom one of the group of three, the one nearest the line of eight. Strip about 1/4" off the end of your wire, tin it with very little solder then cut 1/8" off. Make a very small hook in the end. Wearing your best glasses place the hook over the solder blob and heat it just enough for the solder to flow - don't add any more solder!.
Run the wire back to the capacitor, measure it's length and cut off the excess, strip the end 1/4", tin it, make a hook and solder it into the loop you made in the negative lead. Dress the wire down the side of the PC board against the metalwork. Done, inspect and test.
