Replacement for Maxon MCB-20
Oroville, California People's Republic
#1
My ancient Maxon MCB-20 all-in-handset CB seems to be giving up the ghost so I'm looking to replace it. I've pretty much settled on the Cobra 75WXST as it is very similar to the MCB-20. In fact, it is so similar, I was wondering if they use the same power/antenna/external speaker connection box? If so, I should be able to just disconnect the Maxon handset unit and connect the Cobra handset unit.
So, does anyone here know if the connection boxes are the same?
