Replacements for Baofeng UV82HP
scanmanmi
Central Michigan
A HH is worthless where I live unless it is high power. My UV82 on HP was the only mode that worked. I would like to replace them. The things I didn't like were having to go into programming mode and I believe saving the transmit and receive differently. Also the buttons aren't very useful and the scan is snail pace.
SigIntel8600
Communications Receiver Nut
Pine Barrens
The most important part of any radio is the antenna. Cant stress this enough. Are you planning on working portable, mobile or base? VHF or UHF?
jaspence
Michigan
An older model comercial grade radio such as a Motorola xts or efj5100 will give you much better performance at a very reasonable cost. The efj5100 has been around for a long time, but has the advantage of available software and even FPP on all models. I still use mine as a back up to my mobile when storm spotting, and there is even a 900 MHz version of the 5100.
scanmanmi
Central Michigan
if only used as a "Scanner" aka Monitor, then POWER has no bearing on the suggestions.
Mainly, only, mainly, only,mainly, only,mainly, only,mainly, only,mainly, only,mainly, only,mainly, only,mainly, only,mainly, only,mainly, only,mainly, only,mainly, only,
ko6jw_2
Santa Ynez, CA
Using Baofengs as scanners is a losing proposition. They are slow. They don't cover 700/800MHz. They don't receive aircraft. They don't receive low band. They can't receive any digital modes.
As an amateur hand held they have receivers that easily overload and transmitters the radiate spurs.
Otherwise, what's not to like?
Get a Yaesu FT-65 (around $85) or an FT-60 while they're still available for HT use.
Get a real scanner.
The difference between 5 watts and 8 watts is 2dB. One-third of an S unit.
Dump the Baofeng.
jonwienke
More Info Coming Soon!
VA
I was thinking of Baofeng GT-3TP Mark-III. It's high power. Any opinions on these?
Transmitter power is irrelevant for scanning. All Baofeng radios scan at about 3 channels/sec. A 436 does about 80. If you want to access repeaters, an Anytone 878 is a much better option. A better receiver, cleaner 8-9W output in turbo mode on VHF, and it does DMR.
nd5y
Wichita Falls, TX
They are basically the same as the high power versions of UV-82 & UV-5R with a different case design.
Same programming.
Same slow scan speed.
Same dirty transmitter.
Same easily overloaded receiver that gets worse with a better antenna.
AI7PM
The Intermountain West
Buy a scanner if you want fast scan. Even the real (Kenwood, Icom, Yaesu) HTs do not scan "fast".
As for ham use, stick to the Big Three if you want a quality, technically stable, long lasting product. Kenwood, Icom, Yaesu.
Used commercial/public safety gear is available at bargain prices, and it can't be beat from a tech standards viewpoint. If you can get the bucks together, the newer Kenwood 5000 radios will do analog, NXDN, and your choice of a third mode. P25 or DMR.
rescuecomm
Travelers Rest, SC
Dual band commercial/public radios are available at bargain prices where? The Yaseu FT-65 appears to be more in line with what he is needing to replace.
RS
scanmanmi
Central Michigan
The difference between 5 watts and 8 watts is Go or No Go. It makes a big non-mathematical difference.
Lots of the radios suggested are out of stock. I can only carry one HT so here is what I would like. 8 watts on amateur bands, plus MURS, FRS, under $80. I think they all probably scan. The squelch tail on the UV82 is horrendous! Even when using DCS.
