Replay button
#1
Since the last firmware update I’ve noticed that I have to hold down the replay button for two seconds to play messages. I don’t recall that before, and now it seems that it takes the same long press to start replay as it does to cancel replay. Anyone else notice this?
wildbillx
Cape May, NJ
#2
Look under Pager Configuration Setting (7) tab and under general settings look down for Play Key Setting. You can have press for 2 sec. or Click.
