Al1009
If i do a factory reset will I lose the DMR upgrade that I had installed?
There is nothing that the end user can do, in the normal operation of the scanner (including a reset or replacing the sd card), that would delete the paid upgrades... no matter who installed them.Even if it was installed by a third party?
I'm pretty sure when I first got the scanner that when I pushed Func/0wx I got the weather. Somehow I did something and was scanning all the preprogrammed bands and I ended up locking out all of them by pushing the L/O button twice quickly,newbie, and now I get nothing except a beep. I did a factory reset and nothing happened.
Also, if you have a Sentinel version for your radio, you might be able to read the radio into Sentinel, undo all the locks, and then rewrite Sentinel minus the locks back into the radio.
What do you mean.... nothing happened? Do you mean that the factory reset didn't happen at all? What reset procedure did you use?I did a factory reset and nothing happened.
Are you using software to do your programming? If the lockouts were stored in the software programming, re-uploading would put the lockouts back into the scanner after the reset.I did the reset with no problem and re-uploaded my systems but the reset didn't resolve the problem, maybe it isn't a problem and I'm doing something wrong.
i don't do quick keys, and i have a feeling that the radio was setup at some point for F+0 for the weather and when you reset it it was gone.
my 325 does not do anything with F+0.
HOLD,F,0 turns on the weather priority.
