Resolved LSM Simulcast issues - BCD536HP
ecarvalho
I've resolved (at least improved a lot) simulcast issues with my BCD536HP on a local P25 phase II system.
Items modified:
Threshold changed from AUTO 8 to MANUAL 7
ATT (Attenuation) set to ON
Antenna Yagi (directional) pointing to a direction where signal didn't fluctuate as often
You can hear it (for a limited time) here:
Loudoun County Sheriff Dispatch
I will later take the BCD536HP offline and run the feed from a Linux OP25 box.
Screenshot of ProScan: (Notice the error rate at zero - It does change to 1 sometimes)
That was a very limited time,I tried and it says offline.
On our NJ 700Mhz system the error could be at zero it still garbles,dont want to be a pessimist,but I have been down that road.
I hope you fixed it though.
ecarvalho
yes that feed is offline
i no longer use uniden for any simulcast systems
its a pain to get a decent result although not impossible
a 45 degree inclined factory antenna and attenuation does help
try it
