Retevis RT97 Portable Repeater
SteveSimpkin
Lancaster, CA
I haven't seen any posts about this product yet. The Retevis RT97 is a 10W duplex repeater with a pre-tuned duplexer in a weather resistant metal enclosure. It runs on 12V and sells for around $400 US. It can be ordered with a 5 MHz offset within the 420-450 MHz 70cm ham band. As such it should be useful as a low power ham repeater operating off of a single antenna. I don't think it is legal to use in the US for any other purpose as I can't find any FCC certification for it.
More information is available at the following websites.
RT97 Portable Repeater Power Amplifier UHF
RFI-EMI-GUY
This kills the deal unless you are on the left coast where folks use the reverse split on some UHF repeaters.
4, UHF-5Mhz-Customize: Offset 5mhz, Tx and Rx's frequencies can be customized. But Tx must be higher than Rx
SteveSimpkin
Lancaster, CA
Definitely an inconvenience. Of the 15 70cm repeaters near me, 10 have a -5 MHz and 5 have a +5 MHz offset. I suspect there are other limitations that are more serious.
RFI-EMI-GUY
I always attributed the weird California offset to the availability of many obsolete UHF MTS and IMTS phones that could be easily converted to a repeater but stuck with the TX high.
KK6ZTE
California
I always thought it was because the ex-commercial subscriber gear RX side wouldn't go too far out of band but the TX side would?
