FALSE!
Menu > Settings > Replay Options > Review Recordings > Select closest date & time of your recording session
Yep, that's how I review my recordings. If I find something of interest, then I'll transfer them to a folder on one of the hard drives but it's rare I even do that unless I'm researching a new system or something.
If I need more info, then I'll use the Universal Scanner Audio program that user
@deim wrote. It works well for pulling metadata out of the audio files that would otherwise not be displayed when listening through the scanner.
The SDS models are kinda weird as they use a somewhat cryptic method of folder naming for user recordings unlike the x36HP models that simply use the date and time format for audio file recording folder names.
At least the SDS models display the folder names in an easy readable date and time format when viewing the audio files via the scanner.
I never really understood why Uniden changed the audio folder naming method used in the SDS models.
I never really looked at the names very hard but I assume the folder names may just be the date and maybe the time but in a Hex format instead of something you can easily read when looking at the audio folders outside of the scanner.
