Mike48824
Thoughts on the home patrol-2?
Thinking of getting one?
They don't do DMR or NXDN at all, and they suck at simulcast worse than every other scanner model I've tested. If any of those are on your listening wishlist, pass.
Programming HP, BCDx36 and SDSx00 scanners are all pretty much the same. They all utilize the HP database, and I am pretty sure allow you to enter a zip code to get started.
Ok thanks!im gonna check them out!I would not suggest it for Suffolk County, they are simulcast and the SDS200/SDS100/Unications work much better there.
Anything other than the Uniden SDS scanners will be hit or miss as far as usable reception for simulcast systems as far as scanners go.Which would be the best in the $400-$500 range? Thanks
Have a read here:
Simulcast Distortion - The RadioReference Wiki
wiki.radioreference.com
Have a read here:
