needairtime
Have anyone done some substitutions of RF final power transistors (without hacking the circuit or board -- meaning assuming the transistors are the same form factor)?
Just wonder what the success rate of doing such, or will these transistors succumb badly to impedance mismatch of the circuit board design?
Curious as to what past experience is -- what frequency transmitter, original and replacement transistor?
I suspect if form factor (TO-220->TO-263), mode of operation (BJT->MOSFET), or massive current capability change (20W transistor ->100W transistor) would require significant rework, but assume the form factor is same and wattage/voltage rating is about the same.
I also wonder, as mentioned somewhere else I forget, a lot of the transistors actually mention VSWR 20:1 no-damage guarantees. Some don't mention it. If there's no mention, is there no guarantee (as assumed) or do most transistors go through rigorous testing to reduce RMAs?
