Hello all,
Hope you guys don't mind me asking a few questions as my first post. I think I have an unusual issue and hope you guys can help.
I recently installed a cellular phone booster in my 04 Toyota Tacoma. Even thou it is a double cab, by todays standards it is a small truck.
The cell booster I have is the weBoost Drive Reach. What I have figured out it is basically a bidirectional cell signal repeater. There is a in-cab antenna that the cell phone connects to. The external outside antenna connects to cell towers and is boosted to 50 watts. The outside antenna is a dreaded mag mount. I have separated the two antennas as far as possible but they are still only 6 feet apart. Feed back and oscillations are the big issue. The Drive Reach will self test at start up and if feed back is excessive then the unit will shut down.
I want to change over to a MNO mount and antenna for the cell booster. I already have a MNO 2m/70cm mount so another hole is not a problem.
The question I have is weBoost tech support advised against a MNO mount for this system. They said that the MNO mount will have more internal cab RFI and increase the chance of oscillations.
Would you agree or disagree that a MNO mount is more RF leaky than a mag mount? Could effective shielding be fabricated?
The mount I plan to purchase ether is pre wired with RG/58 or Low Loss 195. Is there any advantage to ether one for RF leakage?
