RFS Cellflex Coax - Opinions
kb2vxa
Banned
Point Pleasant Beach, N.J.
Hi guys,
"Is it comparable to 9913 or LMR-400?"
No, you overlooked the fact that it's 3/8" diameter while those are 1/2" so you'll need special connectors. Then again it's semi-rigid line, sort of a cross between hard line and standard coax but with a twist, the outer conductor isn't braid, it rather resembles BX armored cable used for electrical wiring. Nope, this stuff isn't your average scanner cable.
N
N_Jay
Guest
kb2vxa said:
Hi guys,
Corrugated cable is the STANDARD of the industry.
LMR-400, LMR-600, etc. is a relative newcomer for those who want to save a few $$.
Yes, all corrugated cable needs connectors specifically designed for it.
Andrew is the big company in the market.
pboy
KHKY
kb2vxa said:
Hi guys,
He bought pre-assembled jumper with N connectors already attached.
No need to obtain or install special connectors.
Rigidity and diameter might be an issue depending on how the feedline needs to be routed.
n3bxv
Severn, MD
Yes I bought it pre-assembled with connectors and it has an Andrew part number. You can't beat the price, just above $20 delivered for 10 meters.
Thanks for the link to the product sheet and also to everyone else that responded.
greenthumb
Colorado DB Administrator
This cable is also extremely durable and will last you forever. It's considered more of a "commercial-grade" cable. $20 is a pretty good price, too.
