thomasFlynn
I need to put an antenna outside on the porch . It will not be above the roof line at all .
I want to run RG6 cable from the antennae to a flat cable under the window . Its about a 20ft line and then another 5-6 ft from the inside from the window to scanner . Due you think that it will work. I am going to put the antennae on the side of one of the pillars on the porch . It will only go up to the bottom of the roof.
I am trying to get more signal than from inside mount .
Can anybody tell me whether it will help.
Thank you
Tom Flynn
Thank you
Tom Flynn
