RG316/U received loss ratio question
safetypro79
Scanning since 1967
Anchorage-Alaska, Boise-Idaho, Salem-Oregon
I am using a Diamond K412SNMO using a 1/4 VHF whip which works perfect for: VHF, UHF, and 700 P 25 systems reception (45 miles) with my HP2 in my 2014 SUBARU Outback
with 13.5 feet of RG316/U coax cable.
But I want to relocate the radio to my center console slot and might need to add another 6 ft of the same cable.
Will the added cable result in any noticeable signal loss ? from what I know I suspect not. But wanted to check with the forum group.
I will try to route the original length cable if possible and not using any additional cable if possible.
prcguy
RG-316 is very lossy at 800MHz and you have about 2.3dB loss in 13.5ft at 850MHz. At 150MHz the same run is about 1dB. I would try and replace the entire run with something better.
prcguy
