Hi guys,
Let's clear up a bit of a misunderstanding here.
First, there IS a difference between RG whatever number cable and RG whatever TYPE cable, a BIG difference. Think of it as juice DRINK vs. juice, the drink can be just about any watered down juice or chemical flavored stew while juice is 100% juice. Those extra words are ways to get around the law and fool you into thinking you're bying something you're not.
Rat Shack not withstanding, use your smarts and you can't go wrong no matter where you buy. Forget about super shielded stuff unless you live in a microwave oven (;->) when UV characteristics are more important. You don't want to replace the cable every couple of years when every 10 or so will do. Yes, it all ages and goes bad in time, nothing lasts forever. Hmmm, that's why I stay away from hamfest specials that somebody took down after spending 20 years in hell.
The biggest ripoff I've seen yet is "9913 type" cable which is nothing more than RG-8U polyfoam dielectric coax. BELDEN 9913 is a horse of another color altogether and only Belden makes it, 9913 is a proprietary number. (Note it's not RG anything, it's quite unique.) Technically it's air dielectric semi rigid line, sort of a cross between coax and hard line with exceptionally low loss characteristics. If it has Belden stamped on it you're getting the real McCoy, accept no substitutes.
Consider the fact that a dipole antenna at resonance has a 75 ohm feedpoint impedance making 75 ohm coax ideal as the feedline, not 50 ohm stuff. An SWR meter will show 1.5:1 at best because it's calibrated to 50 ohms but in reality it's a perfect 1:1 match. Now if a 50 ohm antenna common on VHF/UHF is used with 75 ohm coax the same 1.5:1 ratio exists which is inconsequential considering anything under 3:1 is acceptable. Now here we're talking about transmitting and that's the ONLY place SWR is of any consequence.
When it comes to receiving, reflected loss isn't much of a factor especially when transmission line loss so greatly overshadows it. The bottom line and to put it simply is the only REAL consideration is loss in dB per 100' at the highest operating frequency. What you guys really should look into is a chart showing the common types of coax cables and choose what's best vs. what you can afford for your particular application. That will save you Googling all over the place for each cable, Google for the charts. That's right, no one alone has every type listed so you should check out as many as you find. If you want to take the extra step, compile the data into one chart of your own.
Gotcher ears on good buddy? I hope so, you look funny without them. (;->)
