RIB Cable Question
gunz2000
Port Colborne
Wirelessly posted (BlackBerry9300/5.0.0.846 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/107)
I have a Maxton RPC-M5X(M300) universal programing cable with built in RIB, it says its good for the GM300, GTX Mobile and GM388 and ect. I have used it to read the radius M120 and I could read the radio and chang the power settings,
What I need to know is if it will work on the motorola SM50 and Maxtrac mobile with there respected RSS
davidgcet
yes, since it works for those it should work for any of the moto radios using a RJ45 mic jack. you will need an adapter to do CM200/300 radios, but any others work fine.
gunz2000
Port Colborne
So are all the RJ45 style jack's have the same pin out?
davidgcet
yep, mics/programming/etc are interchangable. the CDM has a couple extra pins, but the regular mics/cable work fine since the inner 8 pins are the same. the only real issue is the newer mics with the LED TX indicator won't work on old radios, they will either stick keyed or not pass voice. i just bypass the LED when i have no choice but to use one.
